I previously had a thread open, thought it was resolved but it wasn't.
Having major issues with frame rate on GTA V. Got all settings on Normal, with some settings off. Only getting 30 FPS.
I used to get 60 FPS on High to Very High settings, have reformatted PC and still have the same issue.
AMD 6100 @ 3.30GHz
GTX 660 @ 2 GB
https://linustechtips.com/topic/393797-gta-v-issues-again/
I have V-Sync turned off, it has gone up to 40 FPS. Been like this since the new update, maybe there is an issue?
You bet there is. The last patch broke a lot of things in GTA. I'm also getting way less fps than before.
Mah Build:  CPU: Intel i7-7700K COOLING: NZXT Kraken X52 GPU: Asus Strix GTX 1080 MOBO: Asus Strix Z270F RAM: 16GB GSKILL TridentZ RGB 3000
CASE: In Win 303 STORAGE: Samsung 850 EVO 250GB, Seagate 1TB  SSHD PSU: EVGA Supernova G2 750W
https://linustechtips.com/topic/393797-gta-v-issues-again/#findComment-5314931
me too, i was getting like 60 FPS. Now i'm getting 20-30-60 FPS
It's annoying 20 FPS stays for 10 minutes 30 same and 60 FPS for about few minutes
Rock* WTF
https://linustechtips.com/topic/393797-gta-v-issues-again/#findComment-5314955
Guessing it will be fixed in the Part 2 update soon, or the independence day special
You never know with R*.
https://linustechtips.com/topic/393797-gta-v-issues-again/#findComment-5315178
