Voltage question and protections
It did go down all the way to 192V today and the PC didn't seem to notice. I am more afraid of damaging the brand new PSU but you're saying it's A-OK for it to run? I guess the low voltage means it draws more Amps from the wall?
The PSU won't get hurt if your voltage stays between 90 volts and 260 volts. However there migth be some awful sharp and short spikes on the power grid you can't measure with your voltmeter. The PSU has a spike protection, but it can only stand a limited number of spikes per minute before it overheats.
Nervertheless you don't have to worry about because:
1) In high quality PSUs like the SS, the protection circuit is designed well and can stand a high amount of spikes.
2) Much more cheap devices will die a long time before the SS, if the power grid actually is THAT bad. As long as there aren't a lot of other electronic devices in you house that dies within thre month you are fine.
Due to the fact that power = voltage * corrent the PSU has to draw a bit more current from the wall when the voltage is falling to ensure a constant power output. That's normal.
I'm sure that SS uses a sofisticated voltage ragulation circuit. Therefor it can compensate the voltage fluctuation. Probably the current flowing in and out the buffer condensators increases a bit, but they are fine with that. It may shorten the lifespann by ~0-20% due to the fact they get sligthly hotter. But again, this is only true when running the PSU at 100% load with fluctuating input voltage all the time. You are very faw away from this scenario by using the PSU in your PC (low load most of the time) for only one month.
Long speak short: You are fine ![]()
Also thanks to @blackadder ![]()
