i was downloading some movies on my 2nd old pc, then i plugged it into my main PC and i got a popup that the USB is corrupted and cannot be read!
on the 2nd PC it wants me to format it!
what do i do?? i have tons of stuff on this usb!
        Sample Text ( ͡° ͜ʖ ͡°)
https://linustechtips.com/topic/393274-help-usb-corrupted/
Did you eject it properly?
i dont know ,how do i fix it!?
https://linustechtips.com/topic/393274-help-usb-corrupted/#findComment-5308045
Hate to bring the bad news but you might have lost it. This has happened to me twice after just using the USB to much. Your best bet is to create an image of it if possible and then try formatting it. Otherwise atleast I couldnt find a way to fix other thsn replacing the drive.
sorry,
Sudo Chocolate
https://linustechtips.com/topic/393274-help-usb-corrupted/#findComment-5308213
sorry,
Sudo Chocolate
:( dammit now i lost my minecraft worlds that i had on it,now i got to bring out my old pc
this already happened to me one on the same usb, but i got an option to restore it
https://linustechtips.com/topic/393274-help-usb-corrupted/#findComment-5308243
If it is very important there is probably some way to do it but it would probably cost. Try calling the Manufacturer???
https://linustechtips.com/topic/393274-help-usb-corrupted/#findComment-5308542
i already formated it ;( ,
i was putting some movies from old PC(for downloads only) to my new one ,and to my ipad , so it had to be done ;((((
idk if kingston could do anything about it
https://linustechtips.com/topic/393274-help-usb-corrupted/#findComment-5308636
