Why do website Media Player (What ever you call them) takes so long to buff my internet speed isn't slow my buffer usely ends right after intro of series is done.
I'm the only one using at internet even if they using my internet it doesn't take long at times to finish buffering I'm sick of the pause play action. It's being Bipolar. :(
I scan for virus clear cache and went to speedtest it fine.
https://linustechtips.com/topic/392951-internet-problem/
where do you live? your provider might be  throttling you
CPU: Intel Core i5 4690K @ 4.6Ghz CPU Cooler: Noctua NH-D15 GPU: GTX 1070 TI RAM: Crucial Ballistix Tactical 16GB (4x4) Mobo: ASUS Z97-PRO(Wi-Fi ac) PSU: Corsair RM Series RM750 Case: Fractal Design Define R4 no window
https://linustechtips.com/topic/392951-internet-problem/#findComment-5302926
Could just be low bandwidth availability on the sites you're watching videos on. Can you be more specific (as in, tell us what sites you're trying to watch videos on)?
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
https://linustechtips.com/topic/392951-internet-problem/#findComment-5302952
Anilinkz.tv
It's like crunchyroll just as good as them but FREE
Probably one best probably to watch HD anime for free.
https://linustechtips.com/topic/392951-internet-problem/#findComment-5302967
Yeah, I'll stick with low bandwidth from them. I've had the same thing happen with a few other sites, even on a gigabit connection. videos would either buffer slow enough that I would need to leave it paused for 15-20 minutes
https://linustechtips.com/topic/392951-internet-problem/#findComment-5302981
