if its for gaming take a non "k" serie cpu. overlocking the cpu isnt going to get you better FPS in games. i5-4690 is the standard.
I would pick Fractal Design S over R5.
Regular CD/DVD writer/Reader at 15$ is fine too.
Other thn that his suggestion is great.
https://linustechtips.com/topic/392807-gaming-build-please-help/#findComment-5301206
Hey guys,
My budget is no more then 2 Grand in Australian Dollars (AUD). Looking mainly to game at high 1080p :) i don't mind AMD gaming builds ;p
Here you go! Will play lots of games at MAX settings and you will be set for a few years to come ^_^
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($319.00 @ CPL Online)
Motherboard: ASRock Z97 Anniversary ATX LGA1150 Motherboard  ($129.00 @ Umart)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory  ($99.00 @ CPL Online)
Storage: Samsung 850 EVO-Series 120GB 2.5" Solid State Drive  ($104.00 @ Centre Com)
Video Card: MSI GeForce GTX 980 Ti 6GB Video Card  ($999.00 @ IJK)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($129.00 @ PCCaseGear)
Total: $2001.00
Generated by PCPartPicker 2015-06-24 15:41 AEST+1000
Echelon Mk 2.11
  • Processor: Intel Core i5-6500
  • Cooler: Cryorig H7 (With a 120 mm Thermaltake Riing RGB)
  • Motherboard: MSI B150M Bazooka Plus
  • Memory: 16 (2x8) GB DDR4 Kingston HyperX Fury (Black)
  • Video Card: Sapphire NITRO R9 390 (Stock)
  • Storage:  1 TB Western Digital Blue
  • Power Supply: 520 W Seasonic M12II Evo (with custom extensions and cable combs)
  • Casing: NZXT S340 Elite (Matte Black)
  • Fans: 2x 120 mm & 3x 140 mm Thermaltake Riing RGB
  • Display: 22 " LG Flatron L227WTG-PF LCD (OCed to 76 Hz)
  • Keyboard: Logitech K120
  • Mouse: Logitech G402 Hyperion Fury
  • Mousepad: SteelSeries QcK
  • Operating System: Windows 10 Pro (64-bit)
https://linustechtips.com/topic/392807-gaming-build-please-help/#findComment-5301273
Might as well get an i7 if your dropping 2k on a pc...
For gaming an unlocked i5 + 980 Ti is better.
Echelon Mk 2.11
https://linustechtips.com/topic/392807-gaming-build-please-help/#findComment-5301283
Depends on the resolution.   :D the Fury X I heard stomps the 980 ti at higher resolutions, and as for 1080p I have no clue.  Wish people would add more to their op, so we can go off that.  :S
I dont base my statements on rumors. Like when they said the 390X stomped the 980 but it really was just a neck to neck encounter. So yeah... ^_^
Echelon Mk 2.11
https://linustechtips.com/topic/392807-gaming-build-please-help/#findComment-5301323
Well, that was more based on the resolution.  But, so much can change that.  Drivers to API to hw utilization.
Yes the extra 2GB VRAM of the 390X made a difference on higher resolution gaming especially with AA enabled. Still doesn't justify the word "stomped".
Echelon Mk 2.11
https://linustechtips.com/topic/392807-gaming-build-please-help/#findComment-5301358
Total: $2001.00
hey man what was the reason for that motherboard choice?
https://linustechtips.com/topic/392807-gaming-build-please-help/#findComment-5301378
ASRock are good motherboard manufacturers and also to fit the build in the budget.
Echelon Mk 2.11
https://linustechtips.com/topic/392807-gaming-build-please-help/#findComment-5301389
also it's cheap :D
"THE RED ARMY"
| INTEL i5 4690K | GIGABYTE Z97X GAMING 3 | XFX R9 390X | CORSAIR VENGEANCE PRO 4x2 8GB 1600Mhz | CORSAIR H80i | XFX XTR 650W | 1TB WESTERN DIGITAL CAVIAR BLUE | ADATA SP600 256GB | LOGITECH G502 | CORSAIR VENGEANCE 1400 | CORSAIR K70 MECHANICAL RED | NZXT S340 |
https://linustechtips.com/topic/392807-gaming-build-please-help/#findComment-5302117
