For some reson the option to set the game at 1440p is completely missing from the settings menu. 4k is there though. Can someone tell me why basic things such as a resolution setting is missing from the game?
MainRig- CPU: 4790k, RAM: 32gb 2400mhz, MOBO: Maximus Formula VII, COOLING: Full EK cooling, GPU: Titan X SLI, PSU: 1200w evga , STORAGE: 250gb SSD, 4TB hybrid CASE: 760T, EXTRAS: Sleeved cables
SecondRig- CPU:4690K, RAM: 16gb 1600mhz, MOBO: Maximus Gene VII, COOLING: H105, GPU: 970ftw, PSU: EVG650W,  STORAGE: 250gb SSD, 3TB, CASE: 540air
Steam: pizzatime6 Plus two other pc rigs and a craptop.
https://linustechtips.com/topic/392740-witcher-3-missing-resolution-settings/
Try this http://www.nexusmods.com/witcher3/mods/12/?
EDIT: nevermind there's no option for resolution in this program :( only aspect ratio
Nude Fist 1: i5-4590-ASRock h97 Anniversary-16gb Samsung 1333mhz-MSI GTX 970-Corsair 300r-Seagate HDD(s)-EVGA SuperNOVA 750b2
Name comes from anagramed sticker for "TUF Inside" (A sticker that came with my original ASUS motherboard)
Not only is the resolution settings missing but a fps drop as well. Optimization for this game has major issues here.....
I've played it from 1080p to 1440p to 4k before on Witcher 3 so...
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
Yeah for some reason it was a different issue. I managed to figure it out. Still really annoying, sometimes I hate computers with a passion.
What was the issue? I am curious... On my one I get a wide pallet of resolutions. What monitor do you have?
See my blog for amusing encounters from IT workplace: http://linustechtips.com/main/blog/585-life-of-a-techie/
The monitor didnt have 2k set as a option. I made a custom resolution using the nvidia control panel. After that I had to turn SLI and it solved all my issues. I have no idea why 2k resolution went missing in my desktop settings though. I have the asus 28" 4k monitor.
