Hello I will be building a new computer soon and I think I have everything selected that I want.
Does this sound ok any help/suggestions are appreciated!
I will be doing gaming and rendering/video editing
case
Corsair Obsidian Series 650D (CC650DW-1) Black Aluminum / Steel ATX Mid Tower Case
http://www.newegg.com/Product/Product.aspx?Item=N82E168...
mobo
ASRock X99 Extreme4 LGA 2011-v3 Intel X99 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
ram
G.SKILL F4-3000C15Q-16GRBB
gpu
gtx 980 ti
coler
Noctua NH-D14 SE2011 140mm and 120mm SSO CPU Cooler
hdd
Western Digital WD Green WD20EZRX 2TB
http://www.newegg.com/Product/Product.aspx?Item=9SIA0SX...
psu
CORSAIR RM Series RM750
ssd
samsung 850 pro 256gb
mouse and keyboard
unknown
thermal paste
unknown
https://linustechtips.com/topic/392572-new-build-help/
Umm, Wheres the CPU ?
Most CPU Cooler comes with free Thermal Paste
Theres so many cheap Keyboard and Mouse Combo
Key Switches Guide | LLT Beginner Guide | GPU TDP & Power Consumption Explained | PSU Tier
s a d b o y s 2 0 0 1
https://linustechtips.com/topic/392572-new-build-help/#findComment-5298068
case
mobo
ram
gpu
gtx 980 ti
coler
hdd
psu
ssd
mouse and keyboard
unknown
thermal paste
unknown
If you are looking for a cheap gaming keyboard and mouse combo look into cooler masters octane gaming combo its cheap , has 7 backlighting color options and is a very nice non mechanical keyboard I'm using it still to this date and its very good me and my friend have the same keyboard and mouse  :D hope this helps!
https://linustechtips.com/topic/392572-new-build-help/#findComment-5298227
All of the LGA2011-3 chips do not come with paste or a cooler to go with them.
no i mean most HSF has Thermal Paste in it
https://linustechtips.com/topic/392572-new-build-help/#findComment-5298235
