I am not necessarily new to computers but I would love some help to see if my build will work.
Components:
CPU: Intel core i5 4690k
GPU: Asus gtx 970 Strix
PSU: Corsair Modular 750w
Mobo: EVGA 797 FTW
Ram: Kingston HyperX Fury 16gb
Cooler: Corsair H100i
Case: NZXT h440 (red)
Drives: WD Green 3tb, Samsung 850 evo 250gb
https://linustechtips.com/topic/392440-will-it-work/
very similar to a bould I did for a friend of mine and it shouldn't make any problems at all
CPU: Ryzen 3700X VGA: RX 5700 8G RAM: 32GB 3200MT/s DDR4 Motherboard: B450 Aorus Pro
Storage: 2x1TB Crucial P2, 1TB Crucial MX500, 36TB NAS Cooling: Custom Loop 360mm & 280mm
PSU: Super Flower Golden Green HX 650W Case: Phanteks Enthoo Luxe
https://linustechtips.com/topic/392440-will-it-work/#findComment-5296357
Components:
Mobo: EVGA 797 FTW
The mobo?
https://linustechtips.com/topic/392440-will-it-work/#findComment-5296360
when you copy a name for a mobo copy this :
EVGA Z97 FTW LGA1150
I didn't know what to put here...
https://linustechtips.com/topic/392440-will-it-work/#findComment-5296776
Components:
Mobo: EVGA 797 FTW
Make sure to follow your topics to get updates on replies sent straight to your notifications.
You can use a very helpful site called PCPartPicker (http://pcpartpicker.com/) to help you pick parts for your build. The site will automatically do compatibility checks on your parts and will make sure that you have all of the parts you need. It can show you which site from a trusted list of sites will offer the cheapest price including sales, shipping, and mail in rebates.
As far as the parts you have picked they will work together just fine. Also, dont forget an OS.
"I believe that if life gives you lemons, you should make lemonade... And try to find somebody whose life has given them vodka, and have a party."
-Ron White
https://linustechtips.com/topic/392440-will-it-work/#findComment-5300458
