help a novice out
Go to solution Solved by vSyNd1c4t3,
i need to get a new computer motherboard coz i want the option to add either 2  gpu or something else in future and this motherboard only supports 1 pci express slot but i have know idea where to start so any help would be greatly appreciated
current computer specs
Name Intel Core i7 2600
Specification Intel® Core i7-2600 CPU @ 3.40GHz
Package (platform ID) Socket 1155 LGA (0x1)
1023MB NVIDIA GeForce GTX 550 Ti (Gigabyte)
ram 8gb ddr3
motherboard :   ipisb ch2
requirements
lots of fan headers
must fit all existing components
atx size
under £150 if possible
This is what PCPartPicker came up with. Take your pick.
Edit: you said you wanted SLI, PCPartPicker only found 3 with those parameters.
http://uk.pcpartpicker.com/parts/motherboard/#X=0,40000&s=14&f=2&sort=a8&page=1&l=2
Why do you need to replace your motherboard?
ram 8gb ddr3
requirements
lots of fan headers
atx size
https://linustechtips.com/topic/392433-help-a-novice-out/
Given that it seems like you don't have the unlocked version, it won't be necessary to get a z77 or z67 motherboard but I'd recommend you to still get one for the ability to SLI in the future. Also they're more high-end than other motherboards.
Desktop: The Bluez | CPU: i5-3570k @ 4.5 ghz 1.296V | CPU Cooler: Hyper 212 Evo | Motherboard: P8Z77 M-Pro | Memory: 16 GB 1600Mhz Kingston HyperX
GPU: Asus GTX 780ti DirectCu II | HDD: Some Random Hitachi 1TB, WD Blue 1TB, 850 EVO 500GB | PSU: Rosewill Hive 750W | Case: Enermax Ostrog GT (Blue Ver.)
Laptop: Razer Blade 14 2013 256GB
https://linustechtips.com/topic/392433-help-a-novice-out/#findComment-5296484
ram 8gb ddr3
requirements
lots of fan headers
atx size
7800X3D - MSI B650 MAG Tomahawk - 32GB 6000mhz CL30 - Gigabyte 3080 TI - 2TB NVME - 1000w PSU - ID Cooling 240mm AIO
https://linustechtips.com/topic/392433-help-a-novice-out/#findComment-5296513
i want to replace it coz i want ability to expand in future
https://linustechtips.com/topic/392433-help-a-novice-out/#findComment-5296541
