http://pcpartpicker.com/p/1jODg
This is my future build and I was wondering if I wanted to OC to a decent speed, say 4.2Ghz +, would this be sufficient cooling? I have a CM Storm Scout 2 case and there are 5 spots for fans (I believe all can have 140mm). I have a $20 CM rebate card coming in, eventually, so I wasn't sure if just going for that CPU cooler is worth it or if I should just use that rebate towards another 2 case fans for the top to increase air flow through the case. Basically I just want to know if it's worth investing in a better CPU Cooler for overclocking or if this will do for when I build it. Who knows maybe I'll get santa to bring me an h100i :P
i5 4670k | Sapphire 7950 | Kingston 120GB SSD | Seagate 1TB | G.Skill Ripjaw X Series 8GB
PB238Q | Steelseries Sensei | Ducky DK9087 | Qck Heavy
Build Log: http://linustechtips.com/main/topic/44902-from-imac-to-my-own-creation/
https://linustechtips.com/topic/39224-oc-with-cm-hyper-212-evo/
i always say invest in a good cooler.
Noctua makes some of the best air coolers. They will send you new mounting hardware for free. if a new cpu socket comes out and your upgrading. they have some of the best fans as well. I think the noctua nhd-14 is phenomenal value ( fans alone are worth close to $50 if you bought them individually.), since you will never have to replace it.
if you buy a cheap cooler.... you get what you pay for 9 times outta 10
Mainboard Asrock Z170 OCF CPU 6700k RAM Tridentz 3600 HDD Intel 730 240gb GPU GTX 780ti sc acx PSU Silverstone Strider 1200W  Case Antec 900 Laptop Lenovo Thinkpad T520 build log-   http://linustechtips.com/main/topic/35809-antec-900-the-re-birth-of-a-legend/ Check out the Tech Center https://www.youtube.com/user/prokon24/videos LTT's Unicore King
https://linustechtips.com/topic/39224-oc-with-cm-hyper-212-evo/#findComment-505261
I dont think it will work, as the haswell CPU's tend to get very hot when overclocking because of the internal VRM, so a liquid cooler would be a better idea.  Something like an h80i should be more then enough.
The EVO might be able to get a small overclock though.
https://linustechtips.com/topic/39224-oc-with-cm-hyper-212-evo/#findComment-505267
Overclocking on Haswell chips may vary but I think you will be able to achieve 4.2Ghz on that cooler but its not a guarantee since some chips are horrible at overclocking. I would get a better cooler like a NH D14 or a H220 if you have the money if you want to overclock. I would get another 2 fans on the top for exhaust in order to cool your cpu heatsink. I would go with a 1tb barracuda because it should give you better performance imo.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/39224-oc-with-cm-hyper-212-evo/#findComment-505284
The Evo will be fine for 4.2 ghz and can hit up to 4.4 - 4.5 ghz if you have a good chip.
Edits: http://pcpartpicker.com/p/1knal
https://linustechtips.com/topic/39224-oc-with-cm-hyper-212-evo/#findComment-505295
I think you guys underestimate the Hyper 212.
I ran my 2600K at 4.6GHz on a Hyper 212+ for like a year.  It wasn't 100% Prime stable, no, but I don't fold or mine or anything, so it was fine.
Intel Core i7-7700K | EVGA GeForce GTX 1080 FTW | ASUS ROG Strix Z270G Gaming | 32GB G-Skill TridentZ RGB DDR4-3200 | Corsair AX860i
Cooler Master MasterCase Pro 3 Samsung 950 Pro 256GB | Samsung 850 Evo 1TB | EKWB Custom Loop | Noctua NF-F12(x4)/NF-A14 LTT Special Edition
Dell S2716DGR | Corsair K95 RGB Platinum (Cherry MX Brown) | Logitech G502 Proteus Spectrum | FiiO E17 DAC/Amp | Beyerdynamic DT990 Pro
https://linustechtips.com/topic/39224-oc-with-cm-hyper-212-evo/#findComment-505316
Is that as good of a OC'in mobo? I just threw something up there and haven't looked too much into that part as i used to have a 3570k instead of the 4670k in my parts. There's no SLI but I have to be honest and realize I'm never going to use that :P
https://linustechtips.com/topic/39224-oc-with-cm-hyper-212-evo/#findComment-505563
Speaking of which, the Hyper 212 Evo is even better than the Plus. Ivy and Haswell has had higher temps on avergae when overclocking compared to Sandy. That's why people worry about cooling.
The motherboard is good. People tend to overpay for a motherboard because they hear it is good. Sure there are better but even the cheapest z87 mobo can hit 4.8 ghz if your chip and cooling allows it. If the chip and cooling is bad, even the best motherboard wouldn't make a difference.
https://linustechtips.com/topic/39224-oc-with-cm-hyper-212-evo/#findComment-505580
I got my i7 2700K up to 4.7Ghz stable with a 212 EVO. In the summer the temperature has started to get a bit high, so I brought it down to 4.5Ghz. I get temperatures in the mid 70s at 100% load.
CPU: AMD 3950x Mobo: MSI B550 RAM: 32GB DDR4 GPU: Asus 3080 Strix PSU: Superflower Leadex 3 720w Case: BeQuiet 500DX
Storage: 2TB SSD + 4TB HDD Audio: SMSL 793ii -> HiFiman HE-400 + Mission MS-50 Speakers
https://linustechtips.com/topic/39224-oc-with-cm-hyper-212-evo/#findComment-505613
http://pcpartpicker.com/p/1koOF
I'll go with the h100i, do it right, do it once. Funny thing is, Linus has a video with this case and I believe he also installed the h100i. :D
Now to sell this iMac……..
https://linustechtips.com/topic/39224-oc-with-cm-hyper-212-evo/#findComment-505634
Just go with the build I posted and use a h100i instead...
https://linustechtips.com/topic/39224-oc-with-cm-hyper-212-evo/#findComment-505654
I was thinking the wireless adapter didn't make much of a difference, I only have 50 down here. Also I forgot I had that little more expensive psu in case I did get a second GPU at some point but that probably won't happen so yes your build is better :)
https://linustechtips.com/topic/39224-oc-with-cm-hyper-212-evo/#findComment-507596
In that case, a cheaper but still great wifi adapter: http://pcpartpicker.com/part/tp-link-wireless-network-card-tlwn881nd
https://linustechtips.com/topic/39224-oc-with-cm-hyper-212-evo/#findComment-508962
