All CPUs are compatible with all GPUs* but expect a bottleneck on that 290 with the A10-7800.
Although as PCP says, your case has Front USB3 which your Motherboard does not.
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
https://linustechtips.com/topic/392232-help/#findComment-5293516
Compatible? Yes.
Balanced? No.
If you haven't bought anything yet, let us know your budget and intended use(s) so we can get to work on a proper build.
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
https://linustechtips.com/topic/392232-help/#findComment-5293523
