Hey guys,
Just wondering what kind of graphics card I would need to make a computer 4k capable in some instances. For example, 4k would be used it will be used in a "virtual tour" or just a picture slideshow. So I guess I am asking what GPU i would use for that. Basically I want a graphics card that can go 4k when it needs to and do it smoothly. Dont worry about the monitor setup I have a 4k monitor for when I need it. It is a complicated situation.
Thanks!!!
https://linustechtips.com/topic/392183-odd-build/
Almost any, Intel HD 4600 is enough, Just get a GPU with HDMI 2.0 and/or displayport
My Gaming PC
|| CPU: Intel i5 4690@4.3Ghz || GPU: Dual ASUS gtx 1080 Strix. || RAM: 16gb (4x4gb) Kingston HyperX Genesis 1600Mhz. || Motherboard: MSI Z97S Krait edition. || OS: Win10 Pro
________________________________________________________________
Trust me, Im an Engineer
https://linustechtips.com/topic/392183-odd-build/#findComment-5292974
