Will It Fit?
Go to solution Solved by Zonus,
The legendary Cooler Master "Hyper 212 Plus" will easily fit in there.
It fits your case and matches up with your CPU socket.
It works great for overclocks under the 4.2 - 4.3 GHz range, so I do believe it's a strong candidate.
Benchmarks: http://www.hardwaresecrets.com/cooler-master-hyper-212-plus-cpu-cooler-review/7/
So I recently bought a Corsair Carbide 100R Silent Edition case and I'm wanting to get the Coolermaster Hyper 612 Ver2.0 Air cooler to replace the crappy amd stock cooler that came with my AMD FX 4300,
I'm Don't know if it'll fit or not...
Feedback is welcome...
https://linustechtips.com/topic/391801-will-it-fit/
Try on pcpartpicker should say.
CPU: R5 5800X3D Motherboard - MSI X570 Gaming Plus RAM - 32GB Corsair DDR4 GPU - XFX 7900 XTX 4GB Case - NZXT H5 Flow (White) Storage - 2X 4TB Samsung 990 Pro PSU - Corsair RM100E Cooling - Corsair H100i Elite Capellix Keyboard Corsair K70 (Brown Switches)  Mouse - Corsair Nightsword RGB
https://linustechtips.com/topic/391801-will-it-fit/#findComment-5288014
I have never let my schooling interfere with my education. - Mark Twain
https://linustechtips.com/topic/391801-will-it-fit/#findComment-5288203
