Hi I was wondering how I could record gameplay at the best quality setting possible with my hardware and software, AND stream at the same time to Twitch.tv, hitbox or youtube live.
The following information has the software I use normally.
OBS latest version
NVIDIA Shadowplay
Sony Vegas Pro 11
The following is my hardware, I would also like to ask should I record / stream with intel quick sync Or keep using NVIDIA's GPU encoder ? I want the best quality for my youtube videos possible.
CPU: i5-4690K  No overclock
GPU: EVGA GTX 970 SC ACX
Boot SSD: Samsung 840 EVO 120GB with updated firmware
Mods drive: 320GB seagate momentus thin
Media drive: 500GB WD Blue
Game drive: 1TB WD Black
Finally if anyone can give me good rendering settings or tips for 1080p 60FPS that would be fantastic. ( Sony vegas please )
A side note question would be, If I record at 1080p 50mbps 60FPS is it worth it to upscale the render to like 1440p or 4K for that higher bitrate for youtube ?
https://linustechtips.com/topic/391577-recording-streaming-and-rendering-questions/
@Ariona
Record with ShadowPlay, stream with OBS x264 CPU Encode.
For OBS for best quality use x264
OBS latest version
NVIDIA Shadowplay
Sony Vegas Pro 11
Why you no overclock? You have a K series CPU and a Z series motherboard.
That's what I said lol.
You didn't say anything about quality :D
@Ariona
Can I record AND stream at the same item though?
And also, CPU encode stream to twitch causes major lag on my gaming and stream entirely. My only options are Quick sync and NVENC for OBS.
Yes you can do both at the same time.  However, NVENC and QuickSync need to be streamed at a MUCH higher rate than x264 to achieve the same quality.  Since the max ingest Twitch accepts is 3500kbps upload, x264 is your only choice for quality.  3500kbps quicksync and NVENC video are quite bad.  Your other solution would be to get a capture card to do the processing for you, or if you have a spare older PC, you can use that to offload all processing overheads.
Gaming PC -> Capture Card -> Random PC -> Upload to Twitch
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
I have an Elgato game capture... It can't record at 60FPS but I could use it to do the encoding couldn't I ?
Also Can you explain how for instance, If I wanted to stream with OBS to twitch at 3mbps / 3000kbps using NVENC or quick sync, and wanted to record game play at the same time at 50mbps.
You can record and stream at the same time, but not with the same encoding type.  If you stream with QuickSync, you can record with ShadowPlay.  If you stream with Nvenc, you can record with CPU (fraps).  If you want purely OBS for everything, you can launch 2 instances of OBS with different encoding/record settings and run it as it is.
How can I run 2 OBS programs at once?
