need a $450 build
Go to solution Solved by techguru,
CPU: Intel Core i3-4160 3.6GHz Dual-Core Processor  ($108.99 @ NCIX US)
Motherboard: Gigabyte GA-B85M-DS3H Micro ATX LGA1150 Motherboard  ($55.75 @ OutletPC)
Video Card: Gigabyte Radeon R9 270 2GB WINDFORCE Video Card  ($139.99 @ Newegg)
Case: Thermaltake Commander MS-I ID ATX Mid Tower Case  ($32.99 @ Micro Center)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  ($29.99 @ NCIX US)
Total: $467.45
Generated by PCPartPicker 2015-06-21 17:29 EDT-0400
this is probably the best one...few parts I might change
So I am going to make a pc for my friend a pc and he wants to play minecarft. his price range is about 450 usd. what should i build him. he may end up playing other games too. i would go on pc part picker but if you can help he for the bets price that would be good.
CPUFX 8320, Motherboard ASUS M5A78L-M/USB3 Socket AM3+ AMD, RAM g.skill ripjaws x series (2x8gb), GPUstrix gtx 970, Storage 500gb + 500gb + 250 ssd, PSU EVGA 600w B 80 PLUS BRONZE, Display(s) ASUS VG248QE 24"+ Hisense 24" + Vizio 24", Cooling Cooler Master Hyper 212 EVO, PC Part Picker  http://pcpartpicker.com/p/LFxQ23
https://linustechtips.com/topic/391163-need-a-450-build/
PCPartPicker part list: http://pcpartpicker.com/p/qXPxQ7
Price breakdown by merchant: http://pcpartpicker.com/p/qXPxQ7/by_merchant/
CPU: AMD Athlon X4 860K 3.7GHz Quad-Core Processor  ($69.95 @ NCIX US)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($28.99 @ NCIX US)
Motherboard: Gigabyte GA-F2A88XM-D3H Micro ATX FM2+ Motherboard  ($72.98 @ Newegg)
Memory: Crucial Ballistix Sport 8GB (2 x 4GB) DDR3-1600 Memory  ($50.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($48.75 @ OutletPC)
Video Card: Sapphire Radeon R9 270X 2GB Dual-X Video Card  ($139.99 @ Newegg)
Case: Enermax OSTROG ATX Mid Tower Case  ($39.99 @ Directron)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  ($36.99 @ SuperBiiz)
Total: $477.63
Generated by PCPartPicker 2015-06-21 17:15 EDT-0400
Insert   Dank   Signature   Here.
https://linustechtips.com/topic/391163-need-a-450-build/#findComment-5280118
Total: $477.63
well i would like a more powerfull cpu and the gpu dose not have to be to power full
https://linustechtips.com/topic/391163-need-a-450-build/#findComment-5280194
Believe me, that CPU is fine for Minecraft. The graphics card is what you should focus on, for almost any game.
|  Athlon 750K   |   EVGA GTX 750 Ti FTW  |  Acer Aspire E15 - i5 6200u, 940M  |
|  Sennheiser HD 518   |   FiiO E10K DAC and Amp  |
Moto G (1st Gen)
https://linustechtips.com/topic/391163-need-a-450-build/#findComment-5280213
ok
https://linustechtips.com/topic/391163-need-a-450-build/#findComment-5280228
Total: $467.45
https://linustechtips.com/topic/391163-need-a-450-build/#findComment-5280250
Minecraft don't give a fuck about what GPU you have, it's going to run almost the same on a 250x compared to a 980ti.
https://linustechtips.com/topic/391163-need-a-450-build/#findComment-5280377
Motherboard: Gigabyte GA-F2A88XM-D3H Micro ATX FM2+ Motherboard  ($50.89 @ OutletPC)
Storage: OCZ ARC 100 120GB 2.5" Solid State Drive  ($44.00 @ Newegg)
Video Card: Gigabyte Radeon R7 260X 2GB WINDFORCE Video Card  ($112.98 @ Newegg)
Total: $448.44
Generated by PCPartPicker 2015-06-21 17:53 EDT-0400
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/391163-need-a-450-build/#findComment-5280449
Get him something that will let him experience the fullness of amazing graphics of real PC games, make him ditch Minecraft though please.
CPU Cooler: be quiet! PURE ROCK 87.0 CFM Sleeve Bearing CPU Cooler ($24.90 @ Newegg)
Memory: Team Elite Plus 8GB (2 x 4GB) DDR3-1600 Memory ($43.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($49.99 @ Newegg)
Video Card: XFX Radeon R9 280 3GB Black Edition Double Dissipation Video Card ($151.00 @ Newegg)
Case: Cougar Spike MicroATX Mini Tower Case ($32.99 @ Mwave)
Total: $453.70
Generated by PCPartPicker 2015-06-21 17:55 EDT-0400
https://linustechtips.com/topic/391163-need-a-450-build/#findComment-5280459
Total: $467.45
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/391163-need-a-450-build/#findComment-5280491
fore minecraft i3 can get on igpu 100fps on fancy graphics with 270 and 8gb of ram it can get 120fps with 60mods no problem
Back when I played Minecraft, I had a i5 3450 running at stock 3.1ghz with 6gb of 1600mhz ram, and a HD 5570. I could turn render distance to max with every fancy setting on and get 80-125 fps.
Anything will run Minecraft maxed out at 60fps 1080p, what this build should be about is what will play real PC games well so OP's friend can try new triple A titles. I'm pretty sure if the guy can only spend 450$, it will probably be a long while before he spends significant amounts of money on upgrading.
https://linustechtips.com/topic/391163-need-a-450-build/#findComment-5280979
Total: $467.45
 this is the best one, go for this
https://linustechtips.com/topic/391163-need-a-450-build/#findComment-5280992
Total: $453.70
we like to play it together just for fun. he may get one real game
https://linustechtips.com/topic/391163-need-a-450-build/#findComment-5282489
I would change the case for reasons that you probably know of
https://linustechtips.com/topic/391163-need-a-450-build/#findComment-5282501
Motherboard: Gigabyte GA-H81M-S1 Micro ATX LGA1150 Motherboard ($40.29 @ SuperBiiz)
Memory: Team Dark 8GB (1 x 8GB) DDR3-1600 Memory ($46.99 @ Newegg)
Storage: Crucial BX100 120GB 2.5" Solid State Drive ($64.99 @ NCIX US)
Video Card: EVGA GeForce GTX 750 Ti 2GB Video Card ($129.99 @ B&H)
Case: BitFenix Neos Black ATX Mid Tower Case ($34.99 @ NCIX US)
Power Supply: EVGA 400W ATX Power Supply ($24.99 @ NCIX US)
Total: $451.23
Generated by PCPartPicker 2015-06-21 23:43 EDT-0400
G3258 @ 4.5 | 8GB Team Vulcan RAM | 128GB Kingston V300 SSD (I didn't know what I was doing when I bought it) | MSI H81I Motherboard | Corsair H55 with Noctua NF-P12 | EVGA SSC GTX 960 4GB | OCZ 550W Fully Modular PSU with Noctua NF-A14 | Cooler Master Elite 130 (Soon to be something cool)
https://linustechtips.com/topic/391163-need-a-450-build/#findComment-5282629
