So i have been saving money for the last couple years and i finally have enough to buy the parts. Note: prices are in CAD and from amazon.ca
Storage: Samsung 850 EVO 1TB 2.5-Inch SATA III: 448.00
Graphics Card: EVGA GeForce GTX 970 FTW ACX 2.0 4GB GDDR5 256-Bit: 459.00
Motherboard: ASUS Z97-A ATX DDR3 2600 LGA: 180.00
RAM: 16GB G.Skill DDR3 PC3-12800 1600MHz: 137.00
CPU: Intel Core i7-4790K Processor: 419.00
POWER SUPPLY: EVGA Supernova 750B1 750W:100.00
Case: NZXT Technologies H440 Mid Tower: 162.00
Anti Static: Startech.Com 24X26-Inch Desktop Anti-Static Mat: 25.00
Anti Static: Belkin Anti-Static Wrist Band with Adjustable Grounding: 13.71
Thermal Paste: Arctic Silver 5 3.5g Polysynthetic Silver Thermal Grease: 13.95
Monitor: Samsung SD300 LS24D300HS/ZA 24-Inch: 189.00
Screwdrivers: 45 in 1 Multi-Bit Tools Repair Torx Screw Driver: 18.49
Cooling: NZXT Technologies Kraken X61 280mm: 145.00
Total Cost: 2310.15
Does anyone have any suggestions that i should upgrade? That also goes for downgrading, anything that can be downgraded to save a few dollars without sacrificing much.
https://linustechtips.com/topic/391147-first-build/
Her's some money saved for you, all in CAD, the extra paste and tools on top of that, and you're still ahead by about 5 hundred or so.
CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler  ($140.00 @ Vuugo)
Motherboard: Gigabyte GA-Z97-HD3 ATX LGA1150 Motherboard  ($113.00 @ Vuugo)
Storage: Samsung 850 Pro Series 256GB 2.5" Solid State Drive  ($174.98 @ DirectCanada)
Case: NZXT H440 (Black/Red) ATX Mid Tower Case  ($130.00 @ Vuugo)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  ($69.99 @ Memory Express)
Monitor: BenQ GL2460HM 60Hz 24.0" Monitor  ($179.99 @ Amazon Canada)
Total: $1792.43
Generated by PCPartPicker 2015-06-21 17:05 EDT-0400
https://linustechtips.com/topic/391147-first-build/#findComment-5280027
Total Cost: 2310.15
CPU Cooler: Phanteks PH-TC12DX_RD 68.5 CFM CPU Cooler  ($49.99 @ Amazon)
Motherboard: Gigabyte GA-Z97MX-Gaming 5 Micro ATX LGA1150 Motherboard  ($104.99 @ Micro Center)
Storage: Samsung 850 Pro Series 256GB 2.5" Solid State Drive  ($142.89 @ OutletPC)
Video Card: EVGA GeForce GTX 980 Ti 6GB Superclocked ACX 2.0+ Video Card (2-Way SLI)  ($669.99 @ Amazon)
Total: $2286.66
Generated by PCPartPicker 2015-06-21 18:12 EDT-0400
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/391147-first-build/#findComment-5280573
Total: $2286.66
OP is in Canada.
https://linustechtips.com/topic/391147-first-build/#findComment-5280577
OP is in Canada.
Ugh... Now I have to source parts again...
https://linustechtips.com/topic/391147-first-build/#findComment-5280588
Total Cost: 2310.15
One 980 Ti is double the performance of a 970. How about two for just a little extra?
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($284.98 @ DirectCanada)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  ($118.99 @ NCIX)
Motherboard: Gigabyte GA-Z97X-SOC ATX LGA1150 Motherboard  ($119.99 @ NCIX)
Video Card: Zotac GeForce GTX 980 Ti 6GB AMP! Video Card (2-Way SLI)  ($821.95 @ NCIX)
Case: NZXT Phantom 410 (Black/Orange) ATX Mid Tower Case  ($144.98 @ Newegg Canada)
Total: $2642.72
Generated by PCPartPicker 2015-06-21 18:28 EDT-0400
https://linustechtips.com/topic/391147-first-build/#findComment-5280688
Total Cost: 2310.15
Thermal Compound: Prolimatech PK-3 Nano Aluminum High-Grade 1.5g Thermal Paste  ($7.99 @ Newegg Canada)
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  ($107.98 @ Newegg Canada)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($119.99 @ Canada Computers)
Video Card: Zotac GeForce GTX 980 Ti 6GB AMP! Video Card  ($821.95 @ NCIX)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($129.99 @ NCIX)
Power Supply: SeaSonic 620W 80+ Bronze Certified Fully-Modular ATX Power Supply  ($109.98 @ Newegg Canada)
Total: $1832.58
Generated by PCPartPicker 2015-06-21 20:05 EDT-0400
If you want you can get a 500GB 850 EVO or/and add another 980Ti. Buy then your other accessories.
Echelon Mk 2.11
  • Processor: Intel Core i5-6500
  • Cooler: Cryorig H7 (With a 120 mm Thermaltake Riing RGB)
  • Motherboard: MSI B150M Bazooka Plus
  • Memory: 16 (2x8) GB DDR4 Kingston HyperX Fury (Black)
  • Video Card: Sapphire NITRO R9 390 (Stock)
  • Storage:  1 TB Western Digital Blue
  • Power Supply: 520 W Seasonic M12II Evo (with custom extensions and cable combs)
  • Casing: NZXT S340 Elite (Matte Black)
  • Fans: 2x 120 mm & 3x 140 mm Thermaltake Riing RGB
  • Display: 22 " LG Flatron L227WTG-PF LCD (OCed to 76 Hz)
  • Keyboard: Logitech K120
  • Mouse: Logitech G402 Hyperion Fury
  • Mousepad: SteelSeries QcK
  • Operating System: Windows 10 Pro (64-bit)
https://linustechtips.com/topic/391147-first-build/#findComment-5281249
Total Cost: 2310.15
A decent build. I would suggest a different psu and monitor. The antic-static mat, screwdrivers, and thermal compound should not be needed. A Phillips and slot screwdriver are the most that will be needed. The Phillips for mounting the cooler and drives. The slot may be needed to loosen some of the thumb screws.
With the exception of Windows, all of the items in this build are available from Amazon.ca. Just a bit more expensive.
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($408.98 @ DirectCanada)
Motherboard: Asus Z97-A ATX LGA1150 Motherboard  ($173.98 @ DirectCanada)
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-2133 Memory  ($124.33 @ DirectCanada)
Storage: Samsung 850 EVO-Series 1TB 2.5" Solid State Drive  ($447.98 @ DirectCanada)
Video Card: EVGA GeForce GTX 970 4GB FTW ACX 2.0 Video Card  ($409.99 @ NCIX)
Power Supply: EVGA SuperNOVA GS 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($84.99 @ NCIX)
Operating System: Microsoft Windows 8.1 (32/64-bit)  ($107.92 @ shopRBC)
Monitor: Asus VS239H-P 23.0" Monitor  ($201.50 @ Vuugo)
Total: $2229.67
Generated by PCPartPicker 2015-06-21 20:33 EDT-0400
https://linustechtips.com/topic/391147-first-build/#findComment-5281398
