spark, computer won't turn on
Go to solution Solved by spwath,
Turn off psu for an hour then check on it again, let the capacitors fully discharge, also remove CMOS battery.
Hope this helps
Thanks, but I'm stupid. I did the wrong pins. Works fine now...
Saw spark when shorting power switch pins on mb, and now it won't turn on.
Ideas?
https://linustechtips.com/topic/391083-spark-computer-wont-turn-on/
Ideas?
Hope this helps
Laptop: Thinkpad W520 i7 2720QM 24GB RAM 1920x1080 2x SSDs Main Rig: 4790k 12GB Hyperx Beast Zotac 980ti AMP! Fractal Define S (window) RM850 Noctua NH-D15 EVGA Z97 FTW with 3 1080P 144hz monitors from Asus Secondary: i5 6600K, R9 390 STRIX, 16GB DDR4, Acer Predator 144Hz 1440P
As Centos 7 SU once said: With great power comes great responsibility.
Disconnect it from the wall.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
Hope this helps
