Hey guys I have two gtx 970s in sli and I need help getting the setup process right.  3 of them are dvi and one of them are display port ( I also have a dvi to display port adapter that I can use).
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125684&cm_re=gtx_970_g1-_-14-125-684-_-Product
http://c1.neweggimages.com/BizIntell/item/14/125/14-125-684/f02.jpg
Im not sure If Im just having trouble figuring this out or what.. Ive done surround before on 2 680s but it seems to be more difficult on these.
"45 ACP because shooting twice is silly!"
https://linustechtips.com/topic/390535-nvidia-surround-4-monitors-help/
How are the monitors set up? 3 horizontal and 1 on top?
Wonder if you need an active dp adapter for the 4th monitor for it to work :/
"Accessory Display must be connected to the card with most number of displays."
So plug every monitor exept the last dvi on the first card and you should be good or get another adapter and plug all monitors on 1 gpu.
Also, all 3 monitors for surround needs to be the same resolution (might be able to trick it, but then you will only get lowest resolution available on all 3).
