980Ti by a long shot.
And it's worth pointing out that with the 980Ti you do get more performance per dollar
EDIT: But wait a couple of weeks before ordering as prices may go down due to the release of AMD's new Fury Cards.
System
CPU: Intel Core i7 5820K @4.5GHz - 1.230v  RAM: HyperX Fury DDR4 4x4GB 2666MHz  MB: MSI X99S SLI PLUS  CASE: NZXT H440  CPU-COOLER: Fractal Design Kelvin S24  PSU: Corsair RM1000W w/ white sleeved cable kit  GPU: MSI GeForce RTX 2070 ARMOR  MONITOR: LG 27GL850-B  STORAGE: Samsung 970 EVO 1TB M.2, Samsung 840 EVO 256GB,  WD Red 3TB
Also The 900D worth the money for watercooling?
custom loop? Frantical Design S, it's made for water cooling. Plus even if they are rebrands doesn't mean they aren't good. I'd wait a few weeks for the AMD Fury X, The benchmarks are outdoing the 980Ti and Titan X at $650
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
Umm mate. Those cards are fine, but the R9 290X Crossfire is better bang for buck.
Crossfire and SLI isn't the best solution.
It can create alot of compatibility problems early access games and indie games, more power consumption, noise, and heat.
Dual GPU setups is best suited for enthusiasts//who might wanna do a custom watercooling loop. (although not exclusively)
System
Oh... My R9 285 CFX Disagrees.
Either way, 980 Tis are still over priced, considering after market 980s.
Expensive yes, but not overpriced..
The 980 would be the one being overpriced, You have to consider the overall value of what you get per dollar, where the 980Ti does win.
And i can guarantee the prices will go down after the Fury cards have settled in (if the benchmarks shown off are to be trusted).
System
