SSD power connector damaged
Go to solution Solved by pspfreak,
My 840 pro is the same way. Works just fine. Don't worry about it.
Hey folks,
recently I have been fiddling in my PC, adding custom made PSU extensions and whatnot, and I noticed on my SSD that the "notch" on the power connector is broken off (random pic for reference included)
Does it pose a problem? The SSD is working fine currently and the damage doesn't reach the pins or anything, just the plastic broke off. I am not crazy scared, but just want to make sure, that my SSD will live on ;)
Thanks
https://linustechtips.com/topic/389449-ssd-power-connector-damaged/
No problem. Just don't put the SATA connector on backwards :)
Nude Fist 1: i5-4590-ASRock h97 Anniversary-16gb Samsung 1333mhz-MSI GTX 970-Corsair 300r-Seagate HDD(s)-EVGA SuperNOVA 750b2
Name comes from anagramed sticker for "TUF Inside" (A sticker that came with my original ASUS motherboard)
