FPS drop, please help!
Go to solution Solved by blankoos,
The only way I managed to fix it was to set the monitor from 'Full' to 'Aspect'.
Doing it via the Nvidia Control Panel doesn't work.
(Adjust desktop size and position > Perform scaling on: GPU/Display.
GPU=black bars, Display=stretched.)
Now, I have it set to stretched, 'Display', so I get the 75fps without graphical interference and I've set the monitor to 'Aspect' which removes the 'stretched' effect but keeps the fps, cc, vs, and tb options.
Hi!
When playing CS:GO with an aspect ratio of 4:3 stretched 1152x864 I play on a consistent 75 fps.
But when switching to 4:3 black bars 1152x864 it drops down to 61 - 59.
And whenever it drops down to 59 my screen lags.
Not to mention when ever there's a smoke grenade active.
Nvidia 630 GT.
8gb RAM.
i5-3350p - 3.10GHz
I actually managed to get 120 fps on black bars when I first installed Nvidia software and drivers but when I restarted my computer it was back at 60 fps.
(Edit, I reinstalled all the drivers and CS:GO was on 120fps with a lot of screen taring and stuttering on the first boot. On the second it dropped down to 88fps. On the third 60. Still stuttering with a bit of vertical sync issues. So I'm playing on 4:3 stretched without any graphical interference until I get a new graphics card or until someone provides me with a solution.)
https://linustechtips.com/topic/389135-fps-drop-please-help/
try lowering the graphics settings, and disable AA
Early 2020 Build : Intel i7 8700k // MSI Krait Z370 // Corsair LPX 8x2 16GB // Aorus 5700 XT // NZXT H500
Early 2019 Build : Ryzen 2600X // Asus Tuff X470 // G.Skill Trident Z RGB 8x2 16GB // MSI RTX 2070 // NZXT H500
Late 2017 Build : Intel i7 8700k // Asus Prime Z370-A // G.Skill Trident Z 8x2 16GB // EVGA GTX 1080 Ti  // NZXT S320 Elite
Late 2015 Build : Intel i7 6700k // Asus Maximus VI Gene Z170 //  Corsair LPX 8x2 16GB // Gigabyte GTX 970 // Corsair Air 240
https://linustechtips.com/topic/389135-fps-drop-please-help/#findComment-5253520
i get fps drops on cs:go too, its the game not your hardware, i have a gtx 970.
Gpu: MSI 4G GTX 970 | Cpu: i5 4690k @4.6Ghz 1.23v | Cpu Cooler: Cryorig r1 ultimate | Ram: 1600mhz 2x8Gb corsair vengeance | Storage: sandisk ultra ii 128gb (os) 1TB WD Green | Psu: evga supernova g1 650watt | Case: fractal define s windowed |
https://linustechtips.com/topic/389135-fps-drop-please-help/#findComment-5253568
What cpu you have? CSGO is pretty cpu intensive.
https://linustechtips.com/topic/389135-fps-drop-please-help/#findComment-5253591
Hi!
When playing CS:GO with an aspect ratio of 4:3 stretched I play on a consistent 75 fps.
But when switching to 4:3 black bars it drops down to 61 - 59.
Nvidia 630 GT.
8gb RAM.
1. If you have a amd cpu you fucked.
2. Make sure no fps limit command is in place. Type fps_max 10000 in console.
3. Make sure MSAA is not crazy high.
https://linustechtips.com/topic/389135-fps-drop-please-help/#findComment-5253630
For one I have a gtx 970 and secondly I have a i7 4790, I got stutter on insurgency too and the new update fixed it.
I doubt it's his system tbh. Even though its not the best.
https://linustechtips.com/topic/389135-fps-drop-please-help/#findComment-5254306
https://linustechtips.com/topic/389135-fps-drop-please-help/#findComment-5270233
Did you check if you had any viruses?
https://linustechtips.com/topic/389135-fps-drop-please-help/#findComment-5270257
