blue screen help plz?
Solved by Captain_WD,
so, here goes, my pc keeps on blue screening when i launch nfs the run, all this happend after a failed o.c which i returned to stock immedietly after the first blue screen could any body help me out here please.
specs:
core 2 quad q6600 B3
asus p5q deluxe
western digital wd blue 1tb
4 GB ram
hyper 212 evo
r9 270x
cx500m
win7 64bit
Hey djsoggy1234,
It would be helpful to know the BSOD error code. I would suggest checking all your hardware with a stress test to make sure it performs as it should. Also check your HDD for errors. I would suggest running WD Data Lifeguard Diagnostic tool: http://products.wdc.com/support/kb.ashx?id=psolAa
Try resetting your CMOS battery and put all BIOS settings to stock.
Reinstalling the game might also help if this occurs only with it (and no other games and applications).
Captain_WD.
