I ordered a Athlon x4 860k, hopefully it comes in one piece, So, I just wanted to know is there anything I should know before I upgrade? Any mistakes that you have done?while changing cpu? so, I can be extra careful about those, Currently I have an a4 6300, with r9 270, so I should a get a huge performance boost. I unfortunately don't have anti-static band, so that's one of my concerns
https://linustechtips.com/topic/388736-first-ever-cpu-upgrade/
well, it seems like your 6300 is FM2, and your new one will be FM2+, so i guess its not compatible (as far as googling their sockets)
whats your mobo?
9800X3D - NH-D15S - MSI X670E  -  32GB 6000MHz CL30 - RTX 3080 FTW3 - 970evo 1TB - 980pro 1TB - 970evo 1TB - 970evo+ 2TB -  970evo+ 2TB - 850evo 250GB - WDblack 1TB - WDblue 3TB - HX850i -  27GR95QE-B.AEU - 28MQ780-B - 27GP850-B - 27GL850 - Meshify 2
https://linustechtips.com/topic/388736-first-ever-cpu-upgrade/#findComment-5248074
Don't worry about an antistatic strap, it's not as though the world is going to end if you don't use one. It's very advicable to ground yourself before working on any electronic components, but I've personally never bothered, and I've yet to break my first piece of hardware that way...
Main Rig "Melanie" (click!) -- AMD Ryzen7 1800X • Gigabyte Aorus X370-Gaming 5 • 3x G.SKILL TridentZ 3200 8GB • Gigabyte GTX 970 G1 Gaming • Corsair RM750x • Phanteks Enthoo Pro --
HTPC "Keira" -- AMD Sempron 2650 • MSI AM1I • 2x Kingston HyperX Fury DDR3 1866 8GB • ASUS ENGTX 560Ti • Corsair SF450 • Phanteks Enthoo EVOLV Shift --
Laptop "Abbey" -- AMD E-350 • HP 646982-001 • 1x Samsung DDR3 1333 4GB • AMD Radeon HD 6310 • HP MU06 Notebook Battery • HP 635 case --
https://linustechtips.com/topic/388736-first-ever-cpu-upgrade/#findComment-5248090
I have a fm2+ motherboard, asus a178m-e
nevermind then
https://linustechtips.com/topic/388736-first-ever-cpu-upgrade/#findComment-5248099
