I'm thinking about getting the R9 295x2 and putting it in my Corsair Carbide Spec-01 chassis. I cant find out if you can mount a 120mm rad in the FRONT of this chassis though. I did manage to wiggle in an H100i in the top of the case so I cant mount it in the rear 120mm fan area.
Any ideas?
https://linustechtips.com/topic/388166-carbide-spec-01-front-mounted-gpu-rad/
