Hi guys, I need your advice:
a store near me is making a deal on an old WD black 1TB (WD1002FAEX) but from what I've read it seems like it is worst than the new ones (that's excepted).
I just need help figuring out if the discount is worth it over the performance lost- so the old WD black is 40€, the new one is  88€. I was also considering the WD green or blue or a Seagate one, all for around 60€.
What do you think?
Thanks in advance! :)
https://linustechtips.com/topic/387709-opting-between-hdds/
What do you think?
I'm happy with my seagate st1000dm003 only about 50€
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/387709-opting-between-hdds/#findComment-5232692
Hi there,
A WD1002FAEX , although an older generation is still a WD Black. The only disadvantage to the WD Blue and WD Green is the maximum achievable transfer rate – 150 MB/s for the Blue and Green and 126 MB/s for the Black. But the Black has a Dual processor and five years warranty. WD Green and WD Blue have 2 years.
Edited by alpenwasser
fixed text colour (sorry, was very hard to read on day theme) :-)
https://linustechtips.com/topic/387709-opting-between-hdds/#findComment-5232910
 Hi there,
So on average day-to-day usage will the green/blue be quicker?
https://linustechtips.com/topic/387709-opting-between-hdds/#findComment-5232997
Is it faster than an old WD black though?
don't know, i could run some benchmarks...
would take a while if you're interested
- Ryzen Build -
2x Dell UP2516D
https://linustechtips.com/topic/387709-opting-between-hdds/#findComment-5233065
i ran crystal disk mark, here my scores: (don't know how fast wd black is)
i have two partitions, don't know why they differ
- Ryzen Build -
2x Dell UP2516D
https://linustechtips.com/topic/387709-opting-between-hdds/#findComment-5233166
Thanks for the effort. From what it seems yours is quite faster. I think I might skip on the deal and buy a recent HDD instead
https://linustechtips.com/topic/387709-opting-between-hdds/#findComment-5233214
was curious myself how fast this thing is :D
- Ryzen Build -
2x Dell UP2516D
https://linustechtips.com/topic/387709-opting-between-hdds/#findComment-5233239
Honestly, my opinion is to just buy whatever hard drive is cheapest.  The reason is that all hard drives, regardless of whether they are new / old generation, or 5400rpm / 7200rpm, will all perform about the same, within about 15% of each other.
If you really want speed, you want to get an SSD for your OS / apps / games.  Keep whatever mechanical HDD you have for bulk media storage (music, videos, movies, pr0n), where speed doesn't matter.
Trying to decide between which mechanical HDD is faster is like trying to figure out what bicycle is the fastest.  If you really want speed, you don't get a bicycle, you get a car.
SSD vs HDD Direct Comparison - Identical Drive Images | SSD Boots Windows 7 + Load 27 Apps in 1 Minute | 17 Second Boot - POST to Desktop
Razer Blade 14 (2015) | Core i7-4720HQ | 8GB RAM | GeForce 970M | 500GB M.2 SSD | 14.1" 1920x1080 Display | 4.19 lbs
https://linustechtips.com/topic/387709-opting-between-hdds/#findComment-5233311
