Hi guys I could potentially be buying a new mid tower case. I am looking for something with a side panel window, preferably very large. I am really interested in the corsair air 540, and was wondering if you could suggest cases similar or cases similar to caselabs but in a price range of less than 150 usd.
https://linustechtips.com/topic/387670-new-case-help/
Fractal Design Define R5 comes with a relatively large side panel. You honestly can't go wrong with one, however the 540 from Corsair is a good ATX case
If you want my attention, quote my post or I will not see it. I ignore builds that do not use PCPartPicker.
If I have solved/answered your question, please press "mark solved" to make it easier for the rest of the community find the answer
https://linustechtips.com/topic/387670-new-case-help/#findComment-5232068
Thermaltake Core X9. Big case, plenty of water cooling room, or good airflow for air cooling. Side window, plenty of drive space (unlike the air 540). Total cost? $169.99 USD
Dubs are better than subs
https://linustechtips.com/topic/387670-new-case-help/#findComment-5234090
