*** BEFORE READING, here's my hard drive: Hitachi HTS545050A7E380 (Travelstar Z7K500, 5400 RPM, 2.5", owned since December 25, 2012) // OS: Windows 8.0 ***
Could someone please explain?
Randomly, out of nowhere, I hear my computer making noise and I see this message: "Windows detected a hard disk problem." First thing I do, backup everything I need onto my external drive.
I ran chkdsk and it says there are NO errors on my hard drive!
Now looking at CrystalDiskInfo, I see that my hard disk health is at "Caution", and C5 (Current Pending Sector Count) has a yellow icon before it.
    OS : Windows 8  [6.2 Build 9200] (x64)
  Date : 2015/06/15 19:30:10
-- Controller Map ----------------------------------------------------------
 + AMD SATA Controller [ATA]
   - Hitachi HTS545050A7E380
   - Slimtype DVD A  DS8A9SH
 - Microsoft Storage Spaces Controller [sCSI]
 - DAEMON Tools Virtual SCSI Bus [sCSI]
-- Disk List ---------------------------------------------------------------
 (1) Hitachi HTS545050A7E380 : 500.1 GB [0/0/0, pd1]
           Model : Hitachi HTS545050A7E380
        Firmware : GG2OA6C0
   Serial Number : TE85123RCU2T4W
       Disk Size : 500.1 GB (8.4/137.4/500.1/500.1)
     Buffer Size : 8192 KB
     Queue Depth : 32
    # of Sectors : 976773168
   Rotation Rate : 5400 RPM
       Interface : Serial ATA
   Major Version : ATA8-ACS
   Minor Version : ATA8-ACS version 6
   Transfer Mode : ---- | SATA/300
  Power On Hours : 8258 hours
  Power On Count : 2982 count
     Temperature : 44 C (111 F)
   Health Status : Caution
        Features : S.M.A.R.T., APM, 48bit LBA, NCQ
       APM Level : 4001h [ON]
       AAM Level : ----
C5 100 100 __0 000000000008 Current Pending Sector Count
kompooterz.
https://linustechtips.com/topic/387453-probably-deadly-hard-drive-issue/
It only has a 1 year of run time on it, it might be going slowly. You did the right thing running bench marks and test on it tho. Have you tried defraging it? I would also say a hard drive running at 44c is hotter than mine. Is it in a laptop?
|Casual Rig| CPU: i5-6600k |MoBo: ROG Gene  |GPU: Asus 670 Direct CU2 |RAM: RipJaws 2400MHz 2x8GB DDR4 |Heatsink: H100i |Boot Drive: Samsung Evo SSD 240GB|Chassis:BitFenix Prodigy |Peripherals| Keyboard:DasKeyboard, Cherry MX Blue Switches,|Mouse: Corsair M40
|Server Specs| CPU: i7-3770k [OC'd @ 4.1GHz] |MoBo: Sabertooth Z77 |RAM: Corsair Vengeance 1600MHz 2x8GB |Boot Drive: Samsung 840 SSD 128GB|Storage Drive: 4 WD 3TB Red Drives Raid 5 |Chassis:Corsair 600t
        Firmware : GG2OA6C0
     Queue Depth : 32
       AAM Level : ----
Defrag that shizzle, mah nizzle!
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
My hard drive gets defragged on a daily basis btw, but thanks for trying to help :3
@Luc401: Yep. It is in a laptop.
It's probably just dying. Laptop drives are subject to conditions desktop drives are not, and so it could very well just be dying.
If you ran checks, and got errors, it's probably the SMART system warning of failure.
Probably just need to get a new drive.
Source: I worked in a repair shop for several years, and routinely replaced drives barely over a year old in laptops. At 3 years, its out of warranty and probably just going bad - is common.
D3SL91 | Ethan | Gaming+Work System | NAS System | Photo: Nikon D750 + D5200
Hi there @DJ_Deedahx!
When the drive detects an error during a write operation it can immediately remap to a sector reserved for this purpose. No data is lost. But if the error occurs during a read operation the drive cannot remap the sector because it doesn't know what the data is supposed to be. The drive makes a not of these and will remap them when or if the sector is later written to or if it can be successfully read. The "Pending Sector Count" is the count of these pending sectors, and the Current Pending Sectors are active visible bad sectors that cannot be read but are still visible to the operating system, and these are dangerous and can cause a lot of problems.
Since the program is giving you a caution warning, I would suggest to make a backup of your important data and look for a replacement HDD.
Hope this helps.
Cheers! :)
If this post helped you, please like and choose it as a best answer.   :)
http://www.wdc.com/en/
