DisplayPort to HDMI problem!
Go to solution Solved by Glenwing,
DisplayPort-to-HDMI cables don't work in both directions. Only from DisplayPort source to HDMI monitor. Unless you're using an actual signal converter box and not just a simple adapter cable, it won't work.
Okay, so my brother ordered some XIM4 thing and it just came in. So he wants to move to his desk, and put his Xbox 360 on there and play with his XIM4 on his desk. Well, problem is, he can't fit his TV on his desk because he has too many computers on it, so he wants to just use a spare monitor I have. Well, the monitor doesn't take HDMI, only DP, DVI and VGA. DVI is already taken by his computer, and VGA isn't ideal to play games on. So I was looking around, and found an old DP to HDMI converter. But when I go to change the source on the monitor to DP, it doesn't show anything, just a black screen. However, when I switch to VGA just to test things out, it says "Chck Video Cable" but it doesn't say that with the DP source, so something is wrong. I have the Xbox on of course.
Here is a video of what I'm doing https://www.youtube.com/watch?v=5tHHMDK7XDY&feature=youtu.be
If I helped you out, or just said something you liked, then please Like my post. Thanks! ;)
https://linustechtips.com/topic/386842-displayport-to-hdmi-problem/
Private video, cannot view. Also, please follow your topic to get notifications to replies.
FX-8350 | GA-990FXA-UD3 | G.SKILL 2x8GB 1600MHz | 1TB WD RE4 | CM Hyper 212 EVO | MSI R9 290x Lightning | Corsair AX860i | Silverstone FT05B-W
Pentium G3258 | MSI Z97 PC Mate | G.SKILL 4x4GB 1066MHz | 500GB Samsung 2.5" | Stock cooler | Pending GPU | EVGA 500B | Antec DF-35
GoPro Hero 3 Silver | Netgear R7000 Nighthawk with DD-WRT | HP Officejet Pro 8610 | Canon iP110 | AudioTechnica ATR2500 USB
Downdraft cooler for mITX board (new build) | Desk mount mic stand | Pop filter | Anti-vibration mount for microphone | mITX case | 3rd monitor (matching existing 23.1" | Intel Core i7-4790K (for mITX build)
