I saw this one fellow one the forums which had problems with graphics in the witcher 3. And i think i have the same problem!
I have turned EVERYTHING all the way up, im running the same strix 970 as the other one (and the one linus reviewed).
I run smoothly at 57 fps.
I don't know how to upload the screenshots, as i am new to forums. How do i upload them? They are "too big".
https://linustechtips.com/topic/386774-problem-with-witcher-3/
Imgur.
CPU - FX 8350 @ 4.5GHZ GPU - Radeon 5700  Mobo - M5A99FX Pro R2.0 RAM - Crucial Ballistix 16GB @ 1600 PSU - Corsair CX600M CPU Cooler - Hyper 212 EVO Storage - Samsung EVO 250GB, WD Blue 1TB
https://linustechtips.com/topic/386774-problem-with-witcher-3/#findComment-5219862
Try to capture screen shots in jpeg instead.
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
https://linustechtips.com/topic/386774-problem-with-witcher-3/#findComment-5219864
So what's your problem?
CPU: Intel i7 4790k @4.7ghz - RAM: HyperX Savage 16GB DDR3 Memory @2400mhz - GPU: Nvidia GTX 970 3.5GB @1500mhz - Mobo: Gigabyte Gaming 7 Z97 - Storage: Win10 on 240GB HyperX Predator m.2 SSD, - Ubuntu w/ Gnome 3 on 80GB OCZ Vertex 3 - 500GB Samsung 850 Evo Game Installs - 5TB mass storage - Monitor: 21:9 3440x1440 LG 34UM95 - PSU: Corsair RM 750w - Case: Silverstone FT01 - Cooling: Custom Water Loop
https://linustechtips.com/topic/386774-problem-with-witcher-3/#findComment-5220773
I puke whenever someone has their depth of field on and the sharpness is maxed. :wacko:
Corsair 760T White | Asus X99 Deluxe | Intel i7-5930k @ 4.4ghz | Corsair H110 | G.Skill Ripjawz 2400mhz | Gigabyte GTX 970 Windforce G1 Gaming (1584mhz/8000mhz) | Corsair AX 760w | Samsung 850 pro | WD Black 1TB | IceModz Sleeved Cables | IceModz RGB LED pack
https://linustechtips.com/topic/386774-problem-with-witcher-3/#findComment-5220832
Am I the only one woh can't see anything wrong? I have everything on minimum and the difference is mainly lighting and foliage visibility range, else it's the same and I have no issues.
https://linustechtips.com/topic/386774-problem-with-witcher-3/#findComment-5228021
Same.  It looks completely fine.  It does look like you have sharpening cranked up to max, making it look kinda grainy but other than that, that's how the game is supposed to look.
https://linustechtips.com/topic/386774-problem-with-witcher-3/#findComment-5233303
