I've been looking to change out the case in my build for a new one since i'm upgrading anyway, and i was hoping i could get some case advice.
I'm looking for a case that will fit a 280mm radiator (Corsair H100i gt) in the top, has a windowed side panel, is fairly quiet (with or without custom fans) and is not too crazy looking from the outside.
Decent airflow, mid-tower and the psu hidden from sight (via a basement or just not behind the window) would also be pre's but not necessary. It will also have to fit a fullsized videocard (like a gtx 980 ti).
Pricing doesnt really matter, as long as it's not too rediculously expensive.
Any tips?
https://linustechtips.com/topic/386689-case-advice/
I happen to have the non-windowed version, but I still absolutely agree with the suggestion of the Enthoo Pro. It looks very subtle and the airflow in it is superb.
Main Rig "Melanie" (click!) -- AMD Ryzen7 1800X • Gigabyte Aorus X370-Gaming 5 • 3x G.SKILL TridentZ 3200 8GB • Gigabyte GTX 970 G1 Gaming • Corsair RM750x • Phanteks Enthoo Pro --
HTPC "Keira" -- AMD Sempron 2650 • MSI AM1I • 2x Kingston HyperX Fury DDR3 1866 8GB • ASUS ENGTX 560Ti • Corsair SF450 • Phanteks Enthoo EVOLV Shift --
Laptop "Abbey" -- AMD E-350 • HP 646982-001 • 1x Samsung DDR3 1333 4GB • AMD Radeon HD 6310 • HP MU06 Notebook Battery • HP 635 case --
https://linustechtips.com/topic/386689-case-advice/#findComment-5219239
