100% core clock and memory clock while idle? Help
Solved by flibberdipper,
I'm planning to buy a second monitor this month, now i'm having second thoughts because I idle at 58c on a single monitor
it's 0% on idle, on 100% my load temps are 67-68c. My friend has the same card as me but he idles at 35c so i was really bothered by it
but our load temps are pretty much the same. Does this affect the longevity of the card by any means?
Until you start getting into the 90s you're fine...
