Anybody with LUA skills here?! Need help! (Script error)
Solved by fizzlesticks,
Delete all the files the script makes if there are any (temp.pool, backup.0.somethingorother, etc)
Make a savestate inside of the level you want the script to learn
Go to \bizhawk\SNES\State\ and find the state for the slot you saved it in
Rename that save as DP1.state
Move DP1.state to the same directory you saved the LUA script in
Open the LUA console and drag in the script, it should autorun
