Hello.Earlier this week i came around with some problems with a new graphics card . Now , as i thought , the motherboard was the issue . So i went to somebody and got a new motheboard . Now , my current problems are : Which is the better motherboard .Gigabyte G1 sniper m3 ( the one that has issues with my graphics card ) or P61-DS3-B3 ( the probably best , and most expensive one i could find available in my country with socket 1155 ) ? Now , i would think the sniper is better . If that's so , can someone suggest any means of fixing it ? The board hasn't got a single problem with a gtx 680 , but as soon as i pop in my 980 , it stays locked on splashscreen for about 3 minutes every boot . I can use the P61 , but two things annoy me about it : weaker sound and max 1333 mhz RAM ( i have hyperx predator 2400 mhz , so they are not being used at full speed ) . I don't really see a difference in performance ( maybe even slightly better , i don't know why ) , but it still is annoying.
https://linustechtips.com/topic/386207-motherboard-issues/
Have you tried updating your BIOS?
The product page is here.
One Steam to rule them all, One Sale to find them, One Sale to bring them all and with their wallets, bind them! - r/pcmasterrace 17/01/2014
  • CPU: Intel Core i7 6700k
  • CPU Cooler: CM Hyper 212+
  • RAM: 16GB Kingston HyperX Fury 2400Mhz (2x8GB)
  • GPU: Gigabyte G1 R9 390
  • Mobo: Asus Z170-AR
  • PSU: Antec High Current Gamer 900W
  • Storage: 240GB intel 520 SSD (OS), Sandisk 128GB SSD(Other OS) 2x 2TB Seagate Barracuda
  • Case: Fractal Design R4
https://linustechtips.com/topic/386207-motherboard-issues/#findComment-5220052
you put the bios flash file on a thumb drive and boot into your bios and flash it that way
https://linustechtips.com/topic/386207-motherboard-issues/#findComment-5223638
