Hello all,
I run a stock lenovo k410 motherboard in my rig, had it since I purchased my first ever computer (stock obviously, the k410). I recently moved over to a new case, the Corsair Air 540. Everything was working out great until I realized I have no idea what position to plug the front I/O connectors in. I know the area where they go, it says F_Panel or something of the like, but there is about 4 or 5 cables all labeled accordingly no idea where they go on the connector.
Is there a standard for these, or do I just kinda have to guess and check?
https://linustechtips.com/topic/386192-front-io-connectors/
Hello all,
This manual shows which headers are which for the front panel.
http://www.manualslib.com/manual/325324/Lenovo-Ideacentre-K410.html?page=29#manual
CPU intel potato2 | Motherboard xpotato69 | RAM DDRPotato | GPU potato 6969 Ti | Case potato curbiide | Storage WD potato GB grey | PSU lakesonic 69 potato Watts | Display(s)69" 0.5K potato 69*69 | Cooling 4 heatpipe fried potato | Keyboard 69 key potato switches | Mouse yukon gold potato | Sound 6.9 surround potato | Operating System OS69 potato
CPU I7 5700HQ |  RAM 8gb DDR3 | GPU GTX 960M | Storage 1 TB HGST HDD | Display 15.6" 1080p IPS panel | Keyboard Steelseries RGB | Operating System Windows 10
CPU R7 3800x |  RAM 32 GB 3200MHZ DDR4| GPU RX 5700XT Ref. | Storage 1TB m.2 NVME, 2x 500GB SSD, 4TB and 750gb hdd | Display LG 32GK850F-BKeyboard Aorus K7 with reds | PSU Corsair RM750X | Case Corsair 275R | Operating System Windows 10
https://linustechtips.com/topic/386192-front-io-connectors/#findComment-5212735
F_Panel = Front Panel.
You're gonna have to find a manual for the mobo. it should have the layout in there.
https://linustechtips.com/topic/386192-front-io-connectors/#findComment-5212737
Not listed anywhere on the entire motherboard.
Thats one of the general problems with OEM mobos. You aren't supposed to take them away from original case. You will have to test them one by one to each pin. You may check on some random other mobo manual for layout. Its as good bet as any since I think that they don't have any standard for order.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/386192-front-io-connectors/#findComment-5227818
