Hey guys and dolls a little help if you please.
I recently upgraded my RAM and since doing so my computer shows no picture when I start it up.
I'm running a Gigabyte 78LMT-USB3 the RAM I'm trying to upgrade too is 8GB HyperX Savage
if I place the old RAM in my system works perfectly.
any ideas are greatly appreciated.
Thanks
https://linustechtips.com/topic/385992-a-little-help-guys/
Thanks
What picture?
Please, follow your own posts and mention me in comments, otherwise i won't be able to help you.
Daily OS: OpenBSD -current
https://linustechtips.com/topic/385992-a-little-help-guys/#findComment-5210368
What picture?
Meaning no POST probably.
Run the RAM configuration as it works, then update the BIOS and see if that helps with the new DIMMs.
My M5A78L-M/USB3 never worked with 8GB DIMMs, so I had to go out and buy 4x4GB as well to get the 16GB I wanted.
Sig under construction.
https://linustechtips.com/topic/385992-a-little-help-guys/#findComment-5210369
