Hey linus community i am wondering if you can help me
I currently have the ar drone 1.0, but the battery no longer works, and i cant find any where to buy a new one or second hand (in Australia) so i was wondering if i could the ar drone 2.0 battery will fit and will connect to the old drone.
Thanks
Zach
Its when dragons have so much sex that the cpu cant handle it
https://linustechtips.com/topic/385765-ar-drone-battery-issues/
