i have an i7 4790, i have it currently set to a manual voltage of 1.048v, when i try to do an offset of -10mv to   get the cpu to drop to 1.038v idle and 1.048v load it doesnt work, it just sets it to 1.038v and it stays that way, so the offset is basically acting like a manual voltage,   how can i get my voltage to drop at idle and rise when under load.
Gpu: MSI 4G GTX 970 | Cpu: i5 4690k @4.6Ghz 1.23v | Cpu Cooler: Cryorig r1 ultimate | Ram: 1600mhz 2x8Gb corsair vengeance | Storage: sandisk ultra ii 128gb (os) 1TB WD Green | Psu: evga supernova g1 650watt | Case: fractal define s windowed |
https://linustechtips.com/topic/385373-confused-with-offset-need-help/
fine now guys, i turned off speedstep, c-state and set my voltage as adaptive rather than override.
Adaptive mode is what you want, as you have discovered.
You will want speedstep on, though, as that's the multiplier ramping that you're referring to.  C-states are also useful for power saving.  There's really little reason to turn those things off.
Isopropyl alcohol is all you need for cleaning CPU's and motherboard components.  No, you don't need [insert cleaning solution here].  -Source: PhD Student, Chemistry
Why overclockers should understand Load-Line Calibration.
ASUS Rampage IV Black Edition || i7 3930k @ 4.5 GHz || 32 GB Corsair Vengeance CL8 || ASUS GTX 780 DCuII || ASUS Xonar Essence STX || XFX PRO 1000W
