Hi, guys
It's my first time posting on linus tech tips and I was just wondering what are some safe overclock speeds for my 970. I currently have the core clock set at +104 which is only 1154 in total since I own a reference model. My memory clock is a modest +182. Although,  I haven't touched the core voltage and I don't mind using it if it helps. My reason for this overclock is better performance in Witcher 3.
Thank You for all your help :)
Chris
https://linustechtips.com/topic/385102-reference-gtx-970-safe-overclock/
Hi, guys
Chris
1400 should be good
My arsenal: i7-9700k Gaming Rig, an iPhone, and Stupidity.
Overclocking nowadays is always safe because of the limit they put in their BIOS/driver/software.
Go nuts.
