How are you getting to the spot to choose what you download?
ok i whent to http://support.amd.com/en-us/downloadand then i whent under where is says drivers and support then i pressed windows 8.1 64bit then i installed there catlyist software and when i got to the two green bars it sais  failed to load detection driver
https://linustechtips.com/topic/385050-amd-catalyst-driver-help/#findComment-5198681
have you checked to make sure that you are not already updated some times they will still update but error out at the end.
https://linustechtips.com/topic/385050-amd-catalyst-driver-help/#findComment-5198718
Well these instructions aren't very good or you're going about this wrong.  When you go to the link you've provided just scroll down and under the "Automatically Detect and Install Your Driver" section just click on the orange "Download Now" button.  Then just run the program and it will figure out what video card and everything you have and tell you which driver you need.  No need to select anything.
Also, PLEASE make sure that you have uninstalled any other AMD software before installing the latest driver.
http://support.amd.com/en-us/kb-articles/Pages/GPU57RemoveOldGraphicsDrivers.aspx
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/385050-amd-catalyst-driver-help/#findComment-5201310
