Hello, I just built my pc and when i did the run-check before building in the case, everything worked fine.
But after putting all the components in the case, the computer turns on but there is no signal detected on the monitor.
I have checked on two monitors, so I assume it is not the problem with the monitor.
I would appreciate your help.
https://linustechtips.com/topic/384902-problem-help/
