So I was fantasizing a little bit today and was thinking about a crazy compact build using the Lian Li PC-O6S. Since the case has four expansion slots, I was thinking of grabbing an mATX motherboard like the Asus Gryphon Z97 or the EVGA X99 micro and putting two gtx 970s in SLI. the problem is, the top one would have plenty of air, while the bottom one would be starved. Fortunately however, the case does have water cooling support, so are there any all in one liquid coolers for the 970? I was hoping EVGA would have an AIO solution, but they only have an AIO cooler for the 980 and 980 ti. An AIO cooler for a 960 would work as well. I'm also open to any solution what so ever even if that includes pulling a Linus in any way shape or form
https://linustechtips.com/topic/384520-crazy-build/
Use Reference 970's, they're work better in SLI due to the blower style cooler.
Just remember: Random people on the internet ALWAYS know more than professionals, when someone's lying, AND can predict the future.
i7 9700K (5.2Ghz @1.2V); MSI Z390 Gaming Edge AC; Corsair Vengeance RGB Pro 16GB 3200 CAS 16; H100i RGB Platinum; Samsung 970 Evo 1TB; Samsung 850 Evo 500GB; WD Black 3 TB; Phanteks 350x; Corsair RM19750w.
Laptop: Dell XPS 15 4K 9750H GTX 1650 16GB Ram 256GB SSD
sex hahaha
https://linustechtips.com/topic/384520-crazy-build/#findComment-5192001
One of the cards would still be running hotter than the other since they're stacked directly on top of each other. I'd rather use one aftermarket air cooled and one reference and just liquid cool that one.
https://linustechtips.com/topic/384520-crazy-build/#findComment-5192119
