https://linustechtips.com/topic/384289-recommend-a-wifi-card/#findComment-5188567
The Intel Wireless AC 7260 goes for around 30 bucks. I have one in my ITX rig and it works flawlessly. It's the latest from Intel, so you really can't go wrong with it.
EDIT: Do you need an actual PCI-E adapter or a Mini PCI-E/M.2 card? The one I referred to above was a Mini PCI-E/M.2 card.
https://linustechtips.com/topic/384289-recommend-a-wifi-card/#findComment-5188580
PCIE
Edit: Or USB
https://linustechtips.com/topic/384289-recommend-a-wifi-card/#findComment-5188628
