I think you're limited to either the stock cooler or a 120 AIO cooler. The only one I can find that it's barely compatible is the Noctua NH-L9i but that is advertised as a maximum tdp of 65 watts so it limits your cpu choices even more than the intel stock coolers.
Also this ugly one called Slient X efz-100ha1 that's barely any better than the stock cooler
I say stick with intel's stock cooler
EDIT: I might have found another option, the Scythe Kozuti
Current Rig
Will the stock cooler fit in that case?
