So I love the colour theme of black and green and i love razer so im planning to make a build that incorporates both of these but i have a few questions. I have one main Question and then indivdual product questions that i will put next to the product name. Any replies will be great.
My main question is will my 650w EVGA supernova be powerful enough for this build?
Item list: Blue = To be ordered    Black = currently owned
NZXT H440 Special Edition (Razer) Mid Tower Gaming Case with Side Window - Black- What is the build quality of a h440? and are they fairly silent?
Avexir Venom Series 16GB (4x4GB) DDR3- Ive chose to go with 4 stick for a better build look but would there be a performance advantage of going 2x8 vs 4x4? Also are Avexir a good brand?
ASUS SABERTOOTH Z77 SOCKET 1155 MOTHERBOARD- Im going to have to buy this second hand because i cant find any new ones but what are the risks of buying a second hand mobo?
CableMod E-Series G2 / P2 Cable Kit – BLACK / GREEN- Are cable mods good quality?
NZXT Kraken X61- How hard is this to install? Will it fit?
GTX 980
I5 3570K
EVGA 650w SuperNova
Razer Kraken 7.1 Chroma
Razer Blackwidow Chroma
Razer Deathadder Chroma
https://linustechtips.com/topic/383703-razer-themed-build-help/
NZXT H440 Special Edition Mid Tower Gaming Case with Side Window - Black- What is the build quality of a h440? and are they fairly silent?
GTX 980
I5 3570K
EVGA 650w SuperNova
use pcpartpicker and it will tell you your wattage at the top right corner
i7-5820K | ASUS X99-A | Corsair DDR4 LPX 16 GB | MSI GTX 970 Gaming | Corsair 750D | WD Black 1 TB | MX100 256 GB | EVGA SuperNOVA 750 Watt | ASUS VG248QE | Corsair H105 | K70 MX blues non-RGB | M95 | H1500 | Windows 8.1 64-bit
https://linustechtips.com/topic/383703-razer-themed-build-help/#findComment-5180568
H440 great build quality and make thinner silenter
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/383703-razer-themed-build-help/#findComment-5180587
Do you know whether it is as silent as the define r5?
You wouldn't notice it with your own ear. It's not all about the case. For PURE silence here's a few tips.
Don't use HDDS only SSDs
A Noctua NH-D15 air cooler is much silenter and will allow a pretty nice overclock like an AIO and is much silenter.
You'd wanna replace all,the case fans with fans from eather Noctua or BeQuiet has some silent ones.
Make sure when you get the GPU, do some research and make sure the fans don't sound like hair dryers.
For the PSU Youd wanna find something with like a ECO mode that's shuts down the fan when not needed or a completely fabless PSU.
That's about it but it's not just the case that determines silence.
https://linustechtips.com/topic/383703-razer-themed-build-help/#findComment-5185792
