Multiple Audio Output
Go to solution Solved by blindpulu,
"select the USB routing on the mixer and the device on your Computer" so check if you can change it from the audio device settings. what is the mixers model ?
So I've ran into a bit of a conundrum, I have to dj a wedding for my sister and her fiance, which is fine, however, I can't figure out how to run audio to 2 different devices at the same time. I'm using a Toshiba Qosmio x70 laptop with a usb mixing board, that I could run via usb, or a 3.5mm adapter to 1/4inch jack, and I also want to use my headset for monitoring, which is a Plantronics gamecom 780.
I can't figure out how to run the audio from itunes(although I'm open to using a different program) between both my headset and the mixing board at the same time.
I'm using windows 8, and if anyone has any clues, i'd be glad to hear them. I've looked it up o youtube, and everyone seems to have a device called stereo output in their list, but I don't.
If you have a way to solve this or a program that lets me use 2 outputs at the same time that would be spectactular.
https://linustechtips.com/topic/383598-multiple-audio-output/
usb splitter? do they exist?
RIG:FX-6300@4.5GHz 1.4V with Hyper 212 evo with LTT NF-F12:MSI Overclockers R7 260X:4x4B Crucial Ballistix Sport:GA-970A-UD3P:1TB Seagate Brracuda & 120GB Crucial M500(OS and Programs)&Sandisk SSD PLUS(Games) In a Bitfenix Comrade with an NF-F12 as exhaust and OEM case fan as front intake
''time you enjoy wasting is not wasted time''
https://linustechtips.com/topic/383598-multiple-audio-output/#findComment-5179177
Not "splitters" per se, but USB hubs exist.
https://linustechtips.com/topic/383598-multiple-audio-output/#findComment-5179308
"headset and the mixing board" "headset for monitoring"
so you want to hear the output sound from the mixer ?
so you need to make the mixer route the sound from iTunes to your headphones?
Yeah, im running a headset for my own monitor, and the mixor is output to a pa system, the the mixer needs to be used, and i have to figure out a monitor for myself as well
https://linustechtips.com/topic/383598-multiple-audio-output/#findComment-5179323
off the top of my head im not sure, i know its a pretty cheap one, i think it was like 100 bucks, it only has 4 channels, im using it soley for the connection between pc and PA system so i have more control. I'll find out in a few when my friend gets back to me
EDIT: its the Alesis Multimix 8 USB
https://linustechtips.com/topic/383598-multiple-audio-output/#findComment-5179428
Ok guys, i figured it out, I'm going to run PC to mixer via USB, then mixer to PA system using 1/4 to RCA converter cables, then, the mixer has a 1/4 monitor output, so I'll just have to use my regular headphones instead of my headset as monitors off the board
https://linustechtips.com/topic/383598-multiple-audio-output/#findComment-5180043
