R9 290X Reference Fans
Go to solution Solved by PlayCrackTheSky,
You can't really see the blower fan once you install a corsair hg10 a1 anyway. The fan shroud covers most of it. I guess if you are looking up at your case and can see the bottom side of your gpu...it might be an issue then??
I don't have one YET, but i was wondering if i could replace the blower fan on it for the sake of aesthetics of my build. I was just thinking about it because i plan on putting a Corsair HG10 A1 on it, and i have to take the reference fan off anyways
Like an aftermarket cooler?
CPU intel potato2 | Motherboard xpotato69 | RAM DDRPotato | GPU potato 6969 Ti | Case potato curbiide | Storage WD potato GB grey | PSU lakesonic 69 potato Watts | Display(s)69" 0.5K potato 69*69 | Cooling 4 heatpipe fried potato | Keyboard 69 key potato switches | Mouse yukon gold potato | Sound 6.9 surround potato | Operating System OS69 potato
CPU I7 5700HQ |  RAM 8gb DDR3 | GPU GTX 960M | Storage 1 TB HGST HDD | Display 15.6" 1080p IPS panel | Keyboard Steelseries RGB | Operating System Windows 10
CPU R7 3800x |  RAM 32 GB 3200MHZ DDR4| GPU RX 5700XT Ref. | Storage 1TB m.2 NVME, 2x 500GB SSD, 4TB and 750gb hdd | Display LG 32GK850F-BKeyboard Aorus K7 with reds | PSU Corsair RM750X | Case Corsair 275R | Operating System Windows 10
https://linustechtips.com/topic/383582-r9-290x-reference-fans/#findComment-5178830
I guess i never really thought about not being able to see it :P so no worries for me anymore
https://linustechtips.com/topic/383582-r9-290x-reference-fans/#findComment-5179496
