my problem is with windows 8.1 and my mouse and keyboard first my mouse works except for trying to left click left clicking on anything makes it bring up the properties tab of let's say my google chrome shortcut on my desktop second my keyboard doesn't work at all except for when I hit the e key and it inputs the euro symbol which doesn't make since because I live in the U.S. I even re-installed windows 8.1 via USB
Why can't a Cleric/Priest/Bishop help a beginner KoC? Cause he's No-bless...When I post something, the thread dies.OR I'm incredibly good at giving informations,
OR I'm a thread killer.
Prolly both.
https://linustechtips.com/topic/383305-need-serious-help-please/
Please learn to use punctuation. It makes life easier for whoever is trying to help you out.
A few questions:
Tried different keyboard/mouse?
Different USB ports?
Are you using a USB hub?
Do the peripherals work on a different computer?
Have you installed drivers that have come with your peripherals? (Not often necessary, but may be in your case)
Aragorn (WS): 250D | 6800k | 840 Pro 512GB | Intel 530 480GB  | Asus X99-M WS | 64GB DDR4 | Corsair HX720i | GTX 1070 | Corsair H115i | Philips BDM4350UC 43" 3840x2160 IPS
Gimli (server):  Node 304 | G4560 | ADATA XPG SX8000 128GB | 2x 5TB WD Red | ASROCK H270M-ITX/AC  | 8GB DDR4 | Seasonic 400FL
 Omega (server):                 Fractal Arc Mini R2 | i3 4130 | 500GB Maxtor | 2TB WD Red : Raid 1 | 3TB Seagate Barracuda | 16GB RAM | Seasonic G-450w
Alpha (WS): 900D | 4770k | GTX 780  | 840 Pro 512GB  | GA-Z87X-OC | Corsair RM 850 | 24GB 2400mhz | Samsung S27B970D 2560x1440
https://linustechtips.com/topic/383305-need-serious-help-please/#findComment-5175144
Tried different keyboard/mouse? Different USB ports? Are you using a hub? Do the peripherals work on a different computer?
Yes. I have tried every port usb 2.0 and usb 3.0 as well as ps/2. Nothing works. It as to be a problem with windows itself.
Prolly both.
https://linustechtips.com/topic/383305-need-serious-help-please/#findComment-5175157
What about my other questions? With a clean install, It's less likely to be a Windows issue and more to do with incompatibility or a physical problem with the peripherals.
It is also possible that the device settings are messed up. Is the input language and keyboard layout set correctly. You can check the mouse settings too and make sure that the buttons aren't inverted. Installing the drivers for these devices may or may not solve this but it's worth a shot.
https://linustechtips.com/topic/383305-need-serious-help-please/#findComment-5175218
Has to be windows started doing it after I woke my computer from sleep and is still doing it after fresh install mouse and keyboard work fine in bios, my keyboard driver downloads on its own since it's a razor but still doesn't work after that
Prolly both.
https://linustechtips.com/topic/383305-need-serious-help-please/#findComment-5175257
I meant the offical drivers rather than the default ones (unless microsoft update gets those for you). Did you try checking the device settings?
https://linustechtips.com/topic/383305-need-serious-help-please/#findComment-5175285
Got a generic sub mouse and an old ps/2 keyboard working temp by uninstalling all mouse and keyboard drivers in device manager unplugging the mouse and keyboard restarting and plugging them in after reboot
Prolly both.
https://linustechtips.com/topic/383305-need-serious-help-please/#findComment-5175323
Do your original keyboard and mouse work if you plug them in at the same time as the old ones?
Have you tried going to the razer website and downloading the latest drivers from there just to be sure?
https://linustechtips.com/topic/383305-need-serious-help-please/#findComment-5175354
Going to do that now I'll let you know the results
Prolly both.
https://linustechtips.com/topic/383305-need-serious-help-please/#findComment-5175381
Does the mouse work if you unplug the keyboard? It sounds like your ctrl key is stuck.
fixed was a windows double driver problem
Prolly both.
https://linustechtips.com/topic/383305-need-serious-help-please/#findComment-5230226
