How does MX Red switches feel compared to MX Blue?
Will those extra 5 grams of actuation force that are on blues have a big difference?
Most likely no. I have used both I can tell that the reds are essentially hair triggers, but the blues were pretty light too.
Will I feel a big difference with red, since they don't have tactile feedback?
There is a difference because the reds are linear, but if you bottom out you should be good after getting used to them. However, if you make use of the bump and click of the blues to know where the actuation point is (usually fast typists do this), then it will be harder to get used to the reds.
Generally how do they feel compared to blues?
Reds are very light. As I said before, they are like hair triggers in a sense, so the slightest tap will actuate them. This is good for gaming, but it does take a bit of getting used to because you have to be more sensitive. The blues will most likely feel nicer to type on, but for gaming the reds will probably feel better.
You will have to take this with a grain of salt because keyswitch choice is down to personal preference. I have said reds will probably be better for gaming, but many people like to game with blues or browns. Also, some people prefer reds for typing.
If you don't want to bite the bullet and buy the keyboard, I would suggest buying a sample set from WASD Keyboards - http://www.wasdkeyboards.com/index.php/products/sampler-kit-1/wasd-sampler-kit.html, a friend did this and we both tried them out and came up with our conclusions. It is harder to judge from just one key, but it will give you a much better feel for them if you can't try a keyboard with reds.
Hope this helps :D
