Hi, i have just installed a new fan on to my heatsink and plugged in the 4 pin connector into the cpu fan on the motherboard, the fan is working fine but everytime i start up my computer a error message appears with CPU Fan error. Im not sure what is wrong please could some one help me
thanks
*FIXED*
I added the fan which was the one i took off to my heatsink having 2 fans and then plugged that fan into the cpu fan header and the other into the cpu opt and no error message.
https://linustechtips.com/topic/38317-cpu-fan-error/
What MoBo are you using?
And have you installed it to right header?
https://linustechtips.com/topic/38317-cpu-fan-error/#findComment-492405
Im using the Asus sabertooth 990fx r2.0 and yes i have
Are you sure that it is on CPU fan header, and not on CPU opt?
(Quote my post so i see when you answear) ;)
https://linustechtips.com/topic/38317-cpu-fan-error/#findComment-492440
Is the fan error coming from AI Suite?
i9-9900K || MSI MPG Z390M GAMING EDGE AC || Gigabyte RTX 2080 Super Gaming OC || 16GBCorsair Vengeance LPX 3200Mhz || Samsung EVO 970 Plus Samsung 850 EVO 2TB + Crucial BX100 500GB + 4TB HGST NAS || Factal Design Define Mini C TG || Corsair RM750x || Corsair H100i Pro RGB || Acer Predator XB271HU
https://linustechtips.com/topic/38317-cpu-fan-error/#findComment-493002
