Help! New build wont post code or display anything
Solved by G33k 4 L1F3,
Amd a10 5800
Evga 2133 2x4 ram
Gigabyte f2a88xm-d3h motherboard
Cooler master evo
Corsair cx600m
Evga GeForce 760 acx
Cooler master haf 912
As i said it will not give a beep or display onto the brand new monitor. After about half a minute the 1 fan that is plugged into the mb, besides the cpu fan,stops working.
well... lets start with the basics.
Do you have all the connections needed on the Motherboard in correctly?
Is the CPU placed in the socket correctly?
Is there any bent/missing pins on the APU?
Is the motherboard able to boot from the A10 without a BIOS update?
Does the motherboard need to be OC'd in order to use the 2133mhz RAM?
